Draw Line
Interactive - Cursor
  • Click the left mouse button to indicate the start point of your line.
  • Move the mouse pointer and click again to set the next point in your line.
  • Repeat this process to add as many line segments as you require.
  • Right-click or press Esc to finish your polyline and exit the form.
  • Alternatively press the Space bar to complete this polyline but keep the form open and begin drawing another polyline.
  • Press the Tab key to automatically close the vector.
  • A smooth bezier span can be created by clicking and dragging to modify the curvature. The next span will then also be smoothed. If you want next line to be straight line then you can press S to disable the smoothing.
Creating Tangent Lines
From A Point To An Arc
From An Arc To A Point
From An Arc To Another Arc
Quick Keys
  • Left-click and drag out your shape in the 2D View.
  • With the left mouse button still pressed, enter a quick key sequence detailed below.
  • Release the left mouse button.
Examples
  • 3 . 5 Enter - Adds the next point at a distance of 3.5 along the line direction indicated by current mouse direction
  • 1 , 2 . 5 Enter - Adds the next point at the absolute position 1 in X and 2.5 in Y
Specifying Further Properties
By using specific letter keys after your values, you can also specify the line segment in terms of angle and length. Using the key sequence value A value L creates the next line segment at angle (A) degrees from the last point and with a length(L)
Examples
  • 45 A 3 L - Creates a line segment at 45 degrees and length 3
Next Point
You can also use the form to enter values for each line segment as you go along. The segments can be defined using :
  • The absolute X Y position of the next point
  • The Angle and Length to the next point
The relative offset in X (dx) and Y (dy) to the next point.
Once you have entered the values you wish to use :
  • Click the Add button to enter a new point.
  • The Undo button deletes the last point entered and allows a new point to be added. The Backspace shortcut can also be used for this.
  • The Finish button completes drawing the current line and leaves the form open to allow additional lines to be drawn.
